Camshaft Thrust Plate Bolts
Started by William, Mar 16, 2022, 07:32 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
William
Had some time so thought I would change the o'ring on the camshaft cover plate.
The was some talk that the bolts could be removed with the cover by taking them off with the cover. No such luck for me.
Had to go the tried and tested method of cutting the bolt that fouls on the thermostat housing.
The cut bolt was replaced with a M8x13 which was ground down from a M8x16 from Supercheap.
